Top mount NT turbo manifold
tkelly27
1,712
27
Mar 11, 2007
Gresham, Oregon
http://i67.photobucket.com/albums/h309/tkelly27/IMG_0851.jpg?t=1259200387
So far I have $15 into the manifold, and ~$15 into the 4 90* bends. Manifold is from a hyundai, and the bends come from a local steam fitters (mcmaster is a rip off!). Should be less than $50 with the flange and clear the stock radiator. Probably going to do a holset, or an ebay schwitzer.
Planning on heavily bracing the turbo flange and the pipes. It's too thin to support any weight.
Is it worth keeping them divided? Mating each 1.5" pipe to the split inlet T3 ports is a royal PITA, so I'd rather not.
I'll get some better pics tomorrow.
the 180 coming off the bottom will make it top mount. It's pointing up with the 2 90's sitting under it. Flange may be cut off, may stay to make it a 2 piece manifold, we'll see how much space I wind up with. Mild steel, looks like mig on the factory part, I'll be doing tig.
How are you going to have enough room for all this?
That NA header wasn't made to support any weight or the pressures and heat of a turbo manifold.
The first time it glows red it will flail around like a dead duck.
I'm not sure what you mean by enough room? The turbo will fit in the V of 1-4 runners. Hood may have to be cut, but that's a lot cheaper than a $1200 top mount.
It's just an experiment. Pressure is not an issue, temperature maybe, weight will be fully supported. I've seen turbo manifolds made of thinner material. If it's bolted to the head and the block, the only thing it will have to retain when it glows red is the pressure and thermal expansion. Hoop stress is VERY small, thermal stress, I dunno yet. When/if it fails, and it performs well, I'll make it with sch40 bends. Otherwise, I'll make it similar to the other top mount my friend and I made over the summer out of sch 40
http://i67.photobucket.com/albums/h309/tkelly27/IMG_0633.jpg?t=1259206444
http://i67.photobucket.com/albums/h309/tkelly27/IMG_0649.jpg?t=1259206532
*didn't get pictures of completed manifold*
Here is a bit more of the idea of the thing
http://i67.photobucket.com/albums/h309/tkelly27/IMG_0854.jpg?t=1259261947
that's not where I want everything, but it looks like all the pipes will fit. The main thing I wanted it to fit was the radiator. I obviously wouldn't want the final collector there, that's too low and too close to the radiator. I think a pair of 45's or shallower back towards the engine will work well, but I need the turbo before I go much further.
http://i67.photobucket.com/albums/h309/tkelly27/IMG_0856.jpg?t=1259261949
ugly no?
IMG_0857.jpg picture by tkelly27 - Photobucket
I don't like how the inlets are done. Too small.
IMG_0858.jpg picture by tkelly27 - Photobucket
the pipes are surprisingly thick. Not sch 40 thick, but much thicker than I thought they would be.
