3kgt vr4 front brake, adapter brackets. Need dimensions please!!
constant_proj21
640
3
Jan 27, 2009
Maplewood, Minnesota
Would love if someone could help me out on this one.
I'm planning on doing the 4 pot, 3kgt vr4, front brake upgrade to my car this spring. Now I do realize, that they require custom brackets to mount up, and also realize that there are a few places that sell said brackets. I'm on a budget though, and cannot find it in me to spend $120 on 2 brackets, and 4 bolts.
What I need, is the dimensions of the brackets, if someone has a set they can measure. I have a few friends, that work for a local shop, and are willing to fab up the brackets, once I get those measurements. Would be much appreciated, and you can do your dsmer good deed for the year :D
Thanks for that article. Only thing is, I'm planning on using the VR4 rotors as well, seeing as I got a set of slotted crossed drilled rotors with the calipers. Will that bracket work with them, or no? I was under the assumption, that they were L brackets.
All good, thanks for the link regardless.
So I should say, I'm looking for the dimensions of the L brackets, to mount a 3000gt vr4, 4 piston caliper, and rotor, on to a 1g dsm. I found a guy that's local that has them, but he's currently in the military, so I won't be able to get them from him, for another month of so. So if there's a how to thread I'm not seeing, point it out please!
    • Sdcryan1
