Need Tuner Nation brackets for brake upgrade
604CruisinCroat
366
4
Feb 17, 2003
Vancouver, BC, Canada
Hey guys does anybody have these brackets kicking around or know the measurements of them so I can make them myself ? For reference, it is the vr4 front brake upgrade on a 2g.
Bertha always has them in stock so doubt they will be sold out
By messaging them. Click the link for dsmtuners and it will take you to there page and then message them from there
Click on there picture and then it will bring up an icon display and use start new convosation.
Sorry im using the facebook name in my head. The link i gave you already is technically bertha on FB but different name here sorry for that but http://www.dsmtuners.com/threads/3kgt-vr4-brackets.484662/ again this link click on the person selling them then start a convo with them. I cant do anymore for you so I hope you manage to get them ok from here. @chinola69 hoping this tag might work as that would help you alot!
No problems. Hope i helped you so you can get these brackets
Hey thanks for the tag, all out at the moment could make another batch if enough interest
That part looks real nice. What are the measurements on it? Do you have any comparisons with that and the bracket from RTM with regards to how much clearance is required for the wheels? Neither set of wheels I have would clear the caliper with the RTM bracket without using spacers due to the spokes hitting.
http://www.galantvr4.org/ubbthreads/showflat.php?Board=UBB11&Number=1189407&page=0&fpart=1
I purchased a set of 3KGT brake caliper brackets, and took some measurements so that other members could reproduce these themselves. This may be documented elsewhere, but I never found a good set of measurements that actually made sense. These measurements were taken from my brackets with a Snap On Blue Point dial caliper. Some of the measurements were rounded to make the math add up, but overall the measurements should be accurate to >.010". Please PM me with any questions.
Each of the holes in the bracket are threaded. The first set of bolts go through the steering knuckle and bolt into the bracket. The second set of bolts go through the caliper and bolt into the bracket.
I've already received a few PMs about what rotors these brackets are compatible with. The rotors I have are just typical 3000GT discs much like these: click
(Stock VR4 rotors left, 3KGT rotors right)
This may be obvious, but it's worth noting the 3KGT rotors are 5 lug, yet they are pictured on my 4 lug Galant. Curtis, being the nice guy that he is, went out of his way to do a little writeup on how to drill the 5 lug rotors to fit 4 lug hubs ---> Drilling 5 lug rotors for 4 lug hubs
The brackets I posted measurements of will NOT work with the Cobra rotors to my knowledge. The measurements for 3KGT adapter brackets that use the Cobra rotors are mentioned in this thread ---> click and are pictured below:
More pictures here: http://www.galantvr4.org/ubbthreads...0&page=0&view=collapsed&sb=5&o=&fpart=12&vc=1
I take it these measurements don't do any measuring from center of bolt hole?
Nope, but should be easy to figure out with a bit of math.
  • Wanted 6 bolt NT water pipe
    • chrisman287
