3000GT VR-4 FPR in a 2G
swedeGSX
Feb 27, 2003
Stockholm /Swed, Europe
Can you use a FPR from a 3000GT VR-4? They have 43psi fuel pressure like the 2G, right. And since they make 320hp stock they should flow more than the 2G?
If so that could be a good way for the tuner on a budjet. And if it does fit, does it flow enough for the walbro 255?
Bringing back a long dead thread, but it is a very good idea, I wonder if it would fit, id assume so, plus you can run a 255 HP on it with No over-run.
I run an NT T/E/L FPR and it does the job fine with 255. The base pressure I beleive is 43 psi as well. There are tons of them in every junk yard as opposed to the other one.
I hope you compensated for increasing the fuel preasure.
OE MItsu FPR Info
If you would like to run 47psi for your BFP, get a FPR out of an NA 1.5L SOHC Mitsu Powered car in the bone yards (This includes some Hyundais) ... VERY common & cheap too :D
Otherwise, any 1G AT Turbo DSM also came with a BFP of 43psi. -Look for it's FPR.
What is the advantage of running a 1g AT FPR over a 1g MT FPR? Is it bigger to allow for a bigger pump such as a 255?
