2nd gen block 1st gen head
1g water pipe that runs from the water pump along the top of the block.
1g cam angle sensor would be a good idea
1g intake manifold or cyclone or S/M
(1g thermostat housing connects to radiator hose) VERY IMPORTANT because if you don't have this you will have to weld it so yours will connect to it.
you are still going to use the 2g head bolts when you do this. I would take advantage and get some ARP head studs since you will have the head off any ways.
If your profile is up to date, you will need a 1g water pipe that connects to the lower radiator hose, 1g U pipe that supplies water to the turbo, 1g 3 bolt water neck with 2g sensors, you will need a 1g cam angle sensor unless your intake cam is tapped for a 2g-b CAS, you will also need to block off the water return port on the front of the block (I used an oil drain plug), block off the oil supply port on the head if you are feeding from the oil filter housing.
    • Sdcryan1
