GSLENK
- 1,416
- 55
- May 25, 2011
DC,
Maryland
I was merging onto the highway the otherday, in the rain, and as I was WOT in 3rd on the ramp, I let off, shift into 4th and right around 4-6k rpms the clutch slipped and the engine reved, I backed off a bit, shifted to 5th, same thing, 5-6k rev. (didnt pass 6k because i was aware of it now) It seems like it does this easier in the wet weather than the dry.
Slips only in 4th and 5th around 4-5k under full boost, boost definately dictates slip. A little harder to make slip on hot dry days.
1st and second dont slip, or im not trying hard enough, but i can get full boost without slip. 3rd sometimes does, sometimes doesnt.
My "performance mods" if you can even call them that...
Hallman MBC @14-15 psi
(thats it
other than boost, wb, egr delete, vac lines delete...)
History of car:
Grandpa driven.
clutch replaced at 23k. (has ~25k when it started slipping)
CLUTCH HAS 2-3K miles on it WTF
Heres what the invoice from the previous owner reads:
"Customer states clutch slipping, Inspected, found Clutch seized. Replaced Clutch disk, Pressure plate, Throw out bearing"
Parts-$400 (MU47735-1B)
Labor- $740
(I would hope they would do a good job for that price smh)
All done at a Fitxgerald dealership, In Gaithersburg MD (nicer part of MD) well before it was even being thought of being put up for sale. (this was done in 2008, I got the car this year and 300 miles later)
So my question is/are:
Is it slipping from bad install/sh!tty clutch kit/overpowered/other?
Am I really overpowering with a essentially stock dsm w/ 14psi?
It is out of adjustment? (i hope this is it)
I did some searching, I found RRE adjusting method, ill search the vfaq too.
Any other resources?
Im really dissapointed. a oem spec clutch should last for a lil bit, and a lil more hp than stock... especially if done at a stealership.
It a lot of info I know, where do i start? Im used to clutches lasting practically the life of a car.
I looked up the part number... $130 clutch... installed for $1k, robbery.
(thats it
other than boost, wb, egr delete, vac lines delete...)History of car:
Grandpa driven.
Labor- $740
