420A 2gNT Turbo conversion
edgar7654
May 25, 2010
san antonio, Texas
im trying to build my own turbo kit for a 98GS i saw this on craigslist..... i dont want anything crazy 8psi max will any of this parts work for what i want to do?
thank you and god bless you!!!
http://sanantonio.craigslist.org/pts/2177028324.html
95-99 eclipse turbo gst gsx stock parts
side mount intercooler oem -$45
header oem - $40
oem o2 housing - $30
intake maifold 2g oem $40
2g turbo throttle body $ 40
95 - 96 eclipse turbo ac line $20each
side mount intercooler oem -$45 - YES you can use with universal piping
oem o2 housing - $30 - if you use any MHI turbo you would want to make your own downpipe/ o2 housing because the "exit" of the o2 housing has a angle thats hard to work with when making a DP
intake maifold 2g oem $40 - does not fit on 420a motor.. flanges do not match
2g turbo throttle body $ 40 - uhh doesnt make sense but cant say because anything is possible
95 - 96 eclipse turbo ac line $20each - doesnt do anything for turboing your car
All you need really is your main parts that go on a turbo.
- Side mount intercooler is perfectly fine.
- OEM Manifold or eBay one.
- 14B turbo, o2 housing.
- Piping.
- Stock Turbo Injectors.
- Turbo fuel pump.
- Boost controller.
- 1G BOV + flange. (Or other if you'd like)
- Weld return line to oil pan.
- Custom downpipe to fit up.
- Some way to tune (SAFC, DSMLink, etc...)
From the parts you listed, only 1 is required, which is the side mount. The OEM Manifold can be used, but i'd get an eBay tubular for Mitsu turbos.
By the way, you definitely posted in the wrong section. Definitely should post this in the newbie forum, or even in the main forum. Maybe a mod can fix this? Also, this has been covered quite a few times. A simple search will get you a complete list of parts next time.
