420a turbo conversion
thanks for the input on the 20g, but if i was gun-ho for all out power, I'd probably just step-up to the FP32/ PTE60-1 or something along thouse lines. right now goal is to make it run LOL (is't that the point with these cars??) I'll be using the 14b to break in the motor just to be on the safe side, and if it doest take it out great, i'll clean it up , maybe rebuild it and sell it or something.
I did't have alot of seat time with the Evo3 i had, 400miles before everything went south, now im getting very close to being able to drive it once more, though of just giving up but I'm attached to this , this awd terror of mine.
BTW, does anyone know how to setup the Greddy Profec 2 boost controler? I have the manual but would like someone to explain it a bit better then what im reading LOL
thats a good question looks like a mod merged my thred with yours...WTF
can somebody explain how this would work? SFMU and larger injectors for a fuel setup. I was planing on using a 12:1 FMU but now I want a real setup. What all do I need to use/tune the super f.m.u. and injectors?
An SFMU isn't a real fuel setup, as it functions on the same principles as a conventional FMU., but is definitely better than a 12:1 FMU.
With the SFMU, you change disks and springs to alter it's rise and rate, and a screw to adjust idle fuel pressure. With the larger injectors, you can obviously flow more fuel, but will flow too much at 12:1. With the aide of a wideband, you work your spring and disk combination until you are happy with the AFR's on those injectors and boost setting. The FP will need to be lowered with larger injectors to function properly below boost.
its been a while but heres an update on my progress with the 420a dsm. im kinda planning my next 2 builds at the same time, first im gonna get the turbo sys. on the 2.0 block and get it all running than down the raod when i get this 2.4 block all built im gonna throw it in. im toying with the whole cop setup idea as well. comments, suggestions and criticism are all welcome.
i have the following parts(build 1):
garrett T3 42/48 ar turbo (ported)
FMIC and piping/couplers
external WG
custom tubular header w/equal length runners, WG spot, cut up flange for expansion
walbro 255 lph hp
full 3" turbo back exhaust system w/v-band clamps and a flex section
msns w/boost control, launch control, water injection ect...:cool:
AEM wideband uego
HKS SSQV BOV
stainless lines
EGT gauge
boost gauge
1:1 FPR and gauge
jeep TB bored to 65mm
(build 2)
2.4 block
tons of srt4 shit
UDP
couple 2.4 oil pans
several misc. brackets
pt style rockers/lifters
project head...
shit i got but wont be using:
missing link(dont buy this it is shit)
apexi safc I
apexi afc neo
vortech 12:1 fmu w/some recal. kits
MBC
FCD
the block is a little taller, the crank sensor is on a different cylinder so you gotta rewire the injectors, plugs and rotate the sensors, you use the 2gnt head, you gotta rotate the pistons 180. do some searching, its all out there man. alain has a shit load of posts about the 2.4L swap.
quick update:
i found a evo-III 16g turbo with very little shaft play for 70 bucks!!!
so i gotta modify my header a bit, re-clock the turbo so the j-pipe isn't such a PITA, finish porting(much thanks to the 16g porting tech article), figure out my coolent/oil setup and re-plan my D.P.
im STOKED!!!
