2g wont start after build!
peon_slayer
259
34
Oct 6, 2008
grande prairie, AB, Canada
ok i know atm there are tons of these and i have read them all, but thy dont seem to be having the same problem as me other than it wont start.... sooo
i know i have fuel pressure, spark, and all that other stuff. but whats not happening is my starter doesnt even kick on. i looked on the fuse box and i do not see a starter relay or fuse, i know my alternator relay is shot, would this cause my dsm to not start? i also have no blown fuses in the car other than my alternator relay. is there a way to jump it some how just so i can see how she is running? please any info/pics would be amazing right now
thanks
jordan
ya battery is fine and all the electrical is hooked up, ans as far as i know so is the starter, it only has the power wire, that little clip on the back and the ground.... where should i be grounding it, cause atm its groundedd to the tranny
aer was hooked up correctly, battery was good, had solenoid tested its fine, but when i took the starter back off it would ony rotate if i had something to bridge between the power wire and the solenoid right on the starter... so does this mean my starter is fried?
please i need help really bad this is really pissing me off
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
