2g after installing my 14b it wont start...
99dsmturbo
80
Jun 19, 2006
Manitowoc area, Wisconsin
ok i just finished installing my 14b... it did start before my my oil feed line crack. so i had to buy a new ss oil feed line. after installing it. i tried to start it but it wont.... it doesn't crank or anything. can someone please help. what should i do or look for. thanks.
The oil line will have nothing to do with it not even turning over or anything. Check any wiring around where you worked, reconnect your battery again...may not have made a good connection when you hooked it back up from working. See why your starter is not getting any voltage.
Check the fuses. Check the starter fuse, basically entire electrical stuff as mentioned.
If it does not crank, it has happened to me before. Mine did not crank, but radio, lights, everything else worked. It was the fuse for the starter.
hey blkwidow.... if your car starts. reply and let me know what happened. i'm gonna check my fuse and wires on monday. i'm at work right now so i can't.
My car is still not working. I went to Autozone to go test my battery and found out it was bad. I still don't have a battery so I don't know if it will start yet.
If all of your connections a connected and your car still wont start, check your clutch safety switch.(it will be the one closes to the fire wall)
I just had this problem myself. For some reason the rubber plug they use they used to fill the hole will fall out.
Smiley
yep yep thanks yall.... my car is in good condition now. it starts really good with no problem. i don't know why but it was my battery. i never unplug it and the battery just died out on me.i start it once every week or week & 1/2. never drives it much cause i live about 65 miles from my work, so i'm driving a beat up car that is my gas and mileage saver. yeahhh only one in a while i'll take it for a spin.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
