2g Wheels and Tires Size Questions [merged] fit fitment
ok first off i'd like to say that i did do multiple searches and came up with information that only made me more confused. I want to put a set of 17x8" wheels with 38mm offset 5x114 and 245/45/17 tires. will this fit on my stock 2g or is there something else i need like wheels spacers?
thanks in advance for the help. :dsm:
Yea 245 is too big. 235 is alright, but it will take a little work.
TIRE SIZE RECOMMENDATION REQUEST FORM
Please answer the following questions when requesting tire size recommendations.
1. My car is a:
a) 1g DSM
b) 2g DSM
2. My wheel size is: stock. This is the size i want to put on
Diameter: ___17__
Width: ____8_
Offset: ___38mm__
3. My current or future suspension height will be lowered
a) One inch or less
b) One to 1.5 inches
c) 1.5 - 2 inches
d) More than 2 inches.
4. If suspension is lowered,
a) Rear camber will be adjusted to less than 1° negative.
b) Rear camber will be adjusted to within 1° to 1.5° negative.
c) Rear camber will be more than 1.5° negative.
5. Rear fender flange rolling:
a) My fenders are rolled or will be if necessary.
b) I will not roll the fenders.
6. My driving style is:
a) Street only, with no special performance requirements.
b) Street only, but I like to feel secure on twisty roads.
c) Street and Strip.
d) Street and Autocross.
e) Other
7. I have searched for and read the FAQ's, Tech Articles, and threads on wheel and tire fitment:
a) Yes, but I just need someone with experience to validate my choices.
b) No, I just want someone to tell me what to do.
Ok so i can't run the rims i posted without rolling the rear fenders and changin the rear camber. what would be the widest tire i can run without having to roll the fenders and adjust camber?
I run 17"x8" rims with a 38 offset and 205/50 tires with no problems. I am going to bump it up to a 225/45 when it is time to get new rubber and I shouldn't have any problems.
v8killar said:
Ok so i can't run the rims i posted without rolling the rear fenders and changin the rear camber?
Hey, now. You said before you would roll your fenders.
It's not the wide tires that require camber adjustment, it's the lowering. You said your car would be lowered an inch.
v8killar said:
what would be the widest tire i can run without having to roll the fenders?
225's on +45 offset.
Sorry if i mislead you. i don't plan on droping my car at all. it just didnt have a place to put stock ride height. and i would roll the fenders if i had to. just trying to get an idea of what tire and rim combo i can run without haveing to deal with more headaches then nessecary.
I'm looking at getting 16x7 rims with 205/55-16 size tires...Will they fit on my car (95 Eagle Talon...stock) ? Thanx :talon:
ok.... just wondering if these tires would be good. the reason is because i'm getting 2 of them for free.... the size are 205/40/17. help me if i should buy 2 more and stick with these or go with something else???... thanks.
Those will fit with no problem, but as to if you should buy two more, it depends on how good the tires are. If they are brand new and a good brand name I would, but if they aren't, I would think about going with a 215/45/17. It is a little wider and taller which would help with getting hooked up when you launch.
Yeah they will. You can always check of tirerack for sizes if you aren't sure. They will give you the correct size for tires on any rim.
