2G Starter Plate Problem
You would have to remove the tranny again to install the starter plate because the trans bell housing bolts go through it. You might be able to loosen the starter motor and slightly relocate it a bit before retightening.
+2 I have done the washer trick before. Just not on my dsm. Did it on a suzuki and it worked just dandy.
