99gst_racer
Moderator
- 12,010
- 1,707
- Apr 5, 2003
Coloma,
Michigan
Howdy folks!
I just wanted to start this thread to share a build that I'm working on. The thread title tells all. I'll be working on it this coming week and weekend, and I'll stop in to share updates as I go.
I scooped up a 3/S rearend and narrowed it on a mill so that it would fit in my jig. I utilized the threaded portions of the rear that are typically used to set bearing preload, and I'm using them to adjust to an exact width to locate the rear side to side in the jig.
Shown here, with the welded in slug. My jig locates rearends based on the center of the axle shaft:
I drew up bracketry to bolt to the cover and to each side of the pinion. Extra thick brackets to avoid warpage, yet lightened for weight reduction.
3D drawings:
And here they are in steel:
And here's the mounting points for the lower part of the front cover. This subframe build will be very similar in design to the one I do for the DSM rearend.
More pics coming tomorrow. Thanks for looking!
3D drawings:
