Resolved 2G Plug identification needed under drivers seat.
smevox
Mar 23, 2019
pittsburgh, Pennsylvania
Hi all, Trying to ID this plug and where the blue/White goes.
The car is a 98 GSX.
There are the following wires on this:
Green/Yellow (Which is pin #81 Sensor Impressed Voltage)
Blue/White (No clue where this goes)
Black (Ground)
I believe the Female end is under the drivers seat, as it has matching wires. And looks to be E-44, but doesn't make much sense and doesn't seem to match up with colors.
Please help!!
c-29
blue/white - goes to pin61 on ECU
Hmm, I had thought it was that connector, but I have some doubt.
The only three reasons I didn't think it was this was:
1.) I thought this was only for the 2.4l(Which could be completely wrong)
2.) The plug has 6 ports on it, and the C-29 indicates its only a 3 port plug.
3.) The Female plug in question(That plugs into the one in my previous picture) comes from the Door to under the seat, and according to the documentation for C-29 it comes from the center console out to the center of the seat location.
I mean it really does look like it should be C-29, like 99.9% other than the above.
Thanks for the info, I might just go with what you said and see what kind of errors I see.
i looked it up in the 98 FSM. what year is the manual you are using?
OMG,
Where can I get that?
I'm using 96-97.
I couldn't find any others out there.
That would be AMAZING!!
Thank you!! I grabbed the talon one.
Hopefully it works out, I really appreciate it!!
