RiceKiller_TSi
- 2,938
- 12
- Nov 21, 2003
Mobile,
Alabama
Are all 7 bolt engines considered 2g? If so do they all use the same size pistons and rods?
GSTinCO said:Correct me if I'm wrong but they did put a 7 bolt in later 1G's.
RiceKiller_TSi said:No, you are right. Exactly right. I have a 7 bolt engine in my 1gb. So can I assume that it already has the 2g "big" pistons in it? And the crappy 2g rods?
TargeT said:you would be correct,
BUT, realize these rods have been constantly proven to hold up to 400WHP, its all in how you tune
TargeT said:no reason to bore the cyls unless you have to. Boring out Cylenders is mostly just a trick for big block guys to get more power, we don't have much metal to give so there's no point in it (and the gain is so small its not worth the trouble)
if your doing a rebuild definatly get new rings and have the cylinders re crosshatched, if you have some extra scratch pick up ARP head studs & rod connecters, for the main bearings and rod bearings ( get all new ones also) you can go with the stock mitsu, or if you feel like spending some cash get cleavites (really stock mitsu's are good enough) have a machinie shop check the block & deck it if it needs it (make sure you get your head decked too so the headgasket seals correctly) its best to do it right while your at it, you'll thank your self when you have a relyable car later on![]()
edit : I dont know of any numbers that distinguish the pistons, but if you have a 7 bolt your currently rebuilding, you can take a look at one of em and see
</a>dsm4life said:RiceKiller_TSi you didn't come here to make a choice, you've already made it. You're here to try to understand why you made it.
!! That was GREAT!
You knew I would want that candy.RiceKiller_TSi said:No, you are right. Exactly right. I have a 7 bolt engine in my 1gb. So can I assume that it already has the 2g "big" pistons in it? And the crappy 2g rods?
titogs95 said:
