2G N/A Bad Throttle Position Switch???
Tribal_RS_96
92
Aug 19, 2011
St. Louis, Missouri
Can my TPS be going bad even if it's not throwing my check engine light?
I can push the pedal down while driving and I don't speed up much at all.
No clutch slippage, no head gasket or compression issues.
Could my Vacuum also be backwards somewhere?
I just recently changed the spark plugs within a month, just got new plug wires when i replaced the plugs. I havent touched the fuel filter yet, but the fuel pump is new. I removed my restricted cat and hope to increase the inlet/outlet diameter, but now I have a test pipe on.
