1G 2g MAF Problems
littlewhitedsm
31
Sep 27, 2006
kearns, Utah
Hey Guys I Just Put A 2g Maf On My 92 Talon And I Am Haveing Problems With It The Car Will Idle Fine I Can Rev It Just Fine Then When I Put Load On It, It Will Start To Choke Up Like It Has No Maf Until About 2200 Rpm It Will Clear Up And Run Strong But Then When It Warms Up It Will Start To Take Off Fine Until I Get To About 2500 Rpm And It Will Choke Out So If Anyone Can Help Let Me Know Thanks
no i dont have injectors yet but i was reading around adn it sounds like i am going to need them will i need the safc to run the injectors or will it run without i am planning on a eprom set up and dont want to waste on an safc i do have a logger and thnaks for the advice
THE REAL DEAL said:
you can run the 550s and get pretty close to it running the way it should without the safc.
Are you real sure on that.I am not real familiar with 1G cars but without some kind of correction will it run right?I did not think the 2g mas flowed that much more that you could just throw in 550s and have it run normal.Someone correct me if im wrong.
I have the 2g MAF running fine on 450cc, of course you gotta do a little bit of work with the safc, bit it aint a big deal. More GAS.
