2g head on a 6 bolt
kennyspec
Nov 21, 2008
Stonewall,
Hey quick question on this swap. I am swapping in a 6bolt into a 95 talon TSI AWD and plan to use the 2g head. if i have a complete 6bolt bottom end do i still need to modify the side of the 6 bolt engine block cover found at the start of this link? i know the engine mount needs to be modded.
6 Bolt Motor Install Into a 2G Eclipse
I have read that the head bolts needs to be drilled out to 1/2". should i run the 6 bolt waterpump as well? also I plan to run all the cam sensors from the 2g head for ease of wiring and cost.
Yea like Kevin said the head stud holes on the cylinder head need to be bored out just a little. Do yourself a favor and have this done at a machine shop.
As for the front case, you will need a 6 bolt front case and a 6 bolt water pump. Anything that goes on the block will be 6 bolt for you know including timing belt components.
You can drill the head bolt holes out yourself with a 1/2" drill. The dowels line up the head with the block not the bolts, so slight imperfections in the bolt hole have no effect on head/block alignment. Just make sure to clean any metal shaving out of the head.
ok the link that kevin RR posted is pretty straight forward. one more question, does anyone have a 1G CAS for sale? Also the 6 bolt that i got does not have the timing belt tensioner arm. can i use the one from the 2g?
found a few CAS's on ebay. does it matter what one i get? are some years better than others?
The link I posted is very straight forward and no you can not use the 2g arm. Because it different in size and length. You can use any 1g CAS but the 93-94 is supposedly better.
if you are going to stick with the stock head, and want to get the most potential out of your stock engine, than use the 1g head it has better airflow.
than you dont have to bore out the holes for the headstuds either.
you do have to use the 1gCAS but thats not a big deal.
So got the car up and running. One question though. How do I properly set the CAS timing? I have a timing gun, but in the writeup it says to compare that to the scangauge. Is there any way to set the timing properly without the scan guage?
