2g GSX [email protected] 1.844 sixty 91pump+ meth SBR GT-10
ApexVIII
812
5
Jan 12, 2008
Modesto, California
just got back from the track, i ran a best of a 12.33@118
im on 91 pump + Methanol injection, a M14 jet
1.844 60ft
5.264 330ft
1/8mile 8.003 @ 92.03Mph
¼ mile 12.336 @ 118.145Mph
mods in profile
here is a link to the video!
YouTube - 12.3@118 ApexVIII 95 Eclipse GSX Sac Raceway
here is a 12.4@116
YouTube - 12.4@116 Eclipse GSX 2g DSM Sac Raceway
whats with the nose dive from 1st to 2nd? my front suspension is set to ssuper hard and te rear is on 8th setting of the 16
do i need to do NLTS?
ill post a ECMlink log later today
i weighted it while i was there and it weighed 3080lbs with out me full interior no sun roof no ABS
EDIT: ok i added the log, i forgot for my best pass this 12.3 my laptopshut after the launch so it stopped logging and the file will not open but here is the run befor
those are good numbers. get more seat time and you def have an 11 sec timeslip. if you can get that 60' to a low 1.7 to high 1.6 and a little quicker shifting you should def get some 11.8 or faster.
Nice runs. I would work on the 1-2 shift if you're getting a hard nosedive during the transition. Otherwise the mph is there, just work on the shifting :)
thanks!
yea i seen that in the video's
how do i fix that?
adjust the suspension?
oh this is on 91 + meth
i always forget you guys have crap fuel out their. i guess the 91 is the highest you can get in california?
yea when i get home from work ill upload the log
about 26psi flowing like 43/44 lb/min
Still running the 650's? What's your IDC like? 95%? What pump are you running? 190? Rewired?
Thanks,
Tom
yup FIC 650's
last time i checked it was like 70-75% IDC i believe
im using a M14 jet (14gph) so alot of my fuel is methanol i think i had to drop the sliders 30% to get back to a 11.0 AFR after i installed the kit
the fuel pump is a Evo IX rewired
yup FIC 650's
That makes sense. The 650's should be close to max at 44 lbs/min, but the meth is taking a load off of them. So 70-75% IDC and sliders at -30% makes sense.
Which Meth kit do you have?
Gasoline Systems
Tom
what do you guys do for coilover settings?
hard in the from and soft in the rear?
You typically want it a bit softer in the front so it doesnt squat as much.
i see i will have to adjust the suspension some more next time i go.
That nose dive is from motor movement. My car did the exact same thing before I put in the billet mounts. After the mounts, when you look at my run, you can barely see the 1-2 shift. To get a good launch, I set my coilovers hard in the rear and slightly softer in the front. Setting the front lower than the rear also helps. My 1.6 60' is with cheap low profile tires on 18" wheels.
Nice trap speed, btw.
thanks!
yea i have the energy kit for the motor mount. i guess the front and rear one, which are just inserts are not quite cutting it LOL
by best sixty was like a 1.81 most were like 1.85 :/
  • For sale 2g 2G DSM Link V3
    • frosh29
    • The_Partout_Spot
    • The_Partout_Spot
