General 2G First Log Please help me!
cramec2
56
Sep 7, 2004
Manchester, Connecticut
Ok went for a ride.. 65 degrees out 19lbs boost on pump gas.I have safc2,190 pump, 550's,big 16g,exhaust.I hope this will do for info..
RPM-O2v-Timing
2556 .95 23
2656 .93 20
2768 .93 16
2892 .93 16
3020 .93 10
3168 .97 8
3328 .97 5
3504 .95 5
3704 .95 6
3900 .95 8
4064 .95 8
4288 .95 8
4436 .95 8
4612 .93 9
4816 .93 9
4952 .93 10
5152 .93 9
5272 .91 11
5436 .91 12
5580 .91 12
5756 .91 13
5888 .91 14
6008 .91 16
6152 .91 17
6272 .89 17
6400 .89 17
6516 .89 17
6640 .89 19
6724 .87 38
Looks pretty good. I see a 1 degree timing pull around 5k, but that could be from an increase in coolant temp, rising IAT, etc. Add just a little fuel, maybe 2%, at 5k and see what happens. Also, try adding about 2% from 6 - 7k. Your timing looks like it is getting held by the ECU.
Other than that, it looks good. When you post your next log, can you add airflow?
