ECMlink First log - please help
teamo2t
95
Jan 17, 2007
PARMA, Ohio
I am new to this whole data logging/tuning thing so please be patient. I have followed the information from jeffgst.com (I think that is the site) to tune at idle. I did my first 3rd gear pull and I am not sure what all this info means.
I am using DSMlink and do not have EGT or wide band so I am not sure how to know when I should add or take fuel away. Can some one refer me to a site with detailed info that would help me? Also take a look at my log and provide some suggestions… Thank you all.
It appears you have an air metering issue. BoostEst should be the same as actual boost around 5500 rpm. Check for leaks between the turbo and maf sensor, and check for boost leaks for the hell of it.
I see... I do a boost leak test ASAP then. Thanks for the info. Being new to this whole tuning think sure makes me feel extra dumb...
