First Log and need help please.
EagleTalonTim
830
13
Jan 10, 2007
Brighton, Tennessee
Hey everyone. i finally got me a datalogger and recorded my first log. I have no idea what is best to read these things at, but I took a quick 15 second log when I took off out of my drive way.
Base Timing is set at 5* on the datalogger and 5* BTDC on my motor.
At idle, here are my readings :
RPM : 812 - 843
INJD : 1.5%
Knock : 0
O2-R : 0.05 - 0.74 I think it is actually the front O2. I only have one.
TPS : 9.7%
TIMA : 0*
Now, I got some knock in First gear and I don't know if it is ok. This is right after I backed up and turned around in my drive way. Here are the readings :
Lowest to Highest reading
RPM : 906 - 6937
INJD : 0.0% - 89.8%
Knock : 0 to 9
-- 4 counts of knock started at 1062 RPM's at 32.8% TPS and went to 9 counts at 1781 RPM at 32.8% TPS then went back down to 0 counts at 6093 RPM's at 99.6% TPS. I did not go to WOT till 4875 RPM's.
O2 : 0.00 - 0.82
TPS : 9.7% - 99.6%
TIMA : -1 - 19 The -1 is where the 4 counts of knock started. O2 read 0.05, TPS, 32.8%
I have no idea if this is good or bad and if i should adjust anything at all. After that last splurge of knock counts, I got none through 2nd, 3rd, or 4th. If it makes any difference, I am using my home made shift box for my shifting. Seems like my O2 sensor likes to hang around the .75 +/- .05 when at WOT. Not sure if that is ok either. It is a brand new OEM O2 sensor.
Any help would be appreciated :D If you need any more info, just ask.
That is really freakin' hard to read. Just too many parameters and not enough space on the screen to see everything. Shoot me a PM, I'll give you my email address and you can send me a copy of the log in Excel. I'll try to clean things up and post it up so it's readable.
EDIT Oh, I just noticed that you can click the "email" button at the bottom of my post and send it that way. :) Just make sure you shoot me a PM after you send it, since I don't check that email address very often.
This should help.
Code:
<body link=blue vlink=purple>
<table x:str border=0 cellpadding=0 cellspacing=0 width=384 style='border-collapse:
 collapse;table-layout:fixed;width:288pt'>
 <col width=64 span=6 style='width:48pt'>
 <tr height=18 style='height:13.2pt'>
  <td height=18 width=64 style='height:13.2pt;width:48pt'>TIMA</td>
  <td width=64 style='width:48pt'>FTO2</td>
  <td width=64 style='width:48pt' x:str="TPS ">TPS<span
  style='mso-spacerun:yes'>#</span></td>
  <td width=64 style='width:48pt'>KNCK</td>
  <td width=64 style='width:48pt'>INJP</td>
  <td width=64 style='width:48pt'>AIRT</td>
 </tr>
  <td height=18 style='height:13.2pt'>37.00</td>
  <td>101.40</td>
  <td>15.29</td>
  <td>0.00</td>
  <td>1.79</td>
  <td>108.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>38.00</td>
  <td>77.22</td>
  <td>14.90</td>
  <td>0.00</td>
  <td>1.54</td>
  <td>108.00</td>
 </tr>
  <td>84.24</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.28</td>
  <td>108.00</td>
 </tr>
  <td>88.92</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>108.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>24.00</td>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>108.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>108.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>1.00</td>
  <td>0.00</td>
  <td>108.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>23.00</td>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>108.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>108.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>21.00</td>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>108.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>14.00</td>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>108.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>8.00</td>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.79</td>
  <td>108.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>18.00</td>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.79</td>
  <td>108.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>108.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>16.00</td>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>108.00</td>
 </tr>
  <td>92.82</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.30</td>
  <td>108.00</td>
 </tr>
  <td>85.80</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.56</td>
  <td>108.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>10.00</td>
  <td>77.22</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.30</td>
  <td>108.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>12.00</td>
  <td>79.56</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.30</td>
  <td>108.00</td>
 </tr>
  <td>95.94</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.30</td>
  <td>108.00</td>
 </tr>
  <td>102.18</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.56</td>
  <td>108.00</td>
 </tr>
  <td>100.62</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.56</td>
  <td>108.00</td>
 </tr>
  <td>95.16</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.30</td>
  <td>108.00</td>
 </tr>
  <td>89.70</td>
  <td>25.49</td>
  <td>0.00</td>
  <td>4.86</td>
  <td>108.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>27.00</td>
  <td>94.38</td>
  <td>37.25</td>
  <td>1.00</td>
  <td>6.66</td>
  <td>108.00</td>
 </tr>
  <td>83.46</td>
  <td>41.18</td>
  <td>0.00</td>
  <td>8.19</td>
  <td>108.00</td>
 </tr>
  <td>99.84</td>
  <td>43.14</td>
  <td>0.00</td>
  <td>16.38</td>
  <td>107.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>15.00</td>
  <td>99.84</td>
  <td>43.14</td>
  <td>0.00</td>
  <td>15.10</td>
  <td>105.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>22.00</td>
  <td>99.84</td>
  <td>43.14</td>
  <td>1.00</td>
  <td>13.57</td>
  <td>103.00</td>
 </tr>
  <td>99.84</td>
  <td>46.67</td>
  <td>0.00</td>
  <td>14.08</td>
  <td>101.00</td>
 </tr>
  <td>99.84</td>
  <td>46.67</td>
  <td>0.00</td>
  <td>12.54</td>
  <td>100.00</td>
 </tr>
  <td>99.84</td>
  <td>48.24</td>
  <td>0.00</td>
  <td>16.64</td>
  <td>98.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>17.00</td>
  <td>99.84</td>
  <td>47.84</td>
  <td>0.00</td>
  <td>16.38</td>
  <td>97.00</td>
 </tr>
  <td>99.84</td>
  <td>47.06</td>
  <td>2.00</td>
  <td>15.36</td>
  <td>97.00</td>
 </tr>
  <td>99.84</td>
  <td>45.49</td>
  <td>1.00</td>
  <td>14.08</td>
  <td>97.00</td>
 </tr>
  <td>99.84</td>
  <td>45.10</td>
  <td>1.00</td>
  <td>13.06</td>
  <td>96.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.79</td>
  <td>97.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>39.00</td>
  <td>59.28</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>98.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>26.00</td>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>98.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>25.00</td>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>98.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>99.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>99.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>19.00</td>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>99.00</td>
 </tr>
  <td>99.84</td>
  <td>11.37</td>
  <td>0.00</td>
  <td>1.54</td>
  <td>99.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>29.00</td>
  <td>99.84</td>
  <td>39.22</td>
  <td>0.00</td>
  <td>6.40</td>
  <td>99.00</td>
 </tr>
  <td>99.84</td>
  <td>51.76</td>
  <td>0.00</td>
  <td>11.52</td>
  <td>99.00</td>
 </tr>
  <td>99.84</td>
  <td>51.76</td>
  <td>0.00</td>
  <td>17.41</td>
  <td>99.00</td>
 </tr>
  <td>99.84</td>
  <td>51.76</td>
  <td>0.00</td>
  <td>16.64</td>
  <td>99.00</td>
 </tr>
  <td>99.84</td>
  <td>54.51</td>
  <td>0.00</td>
  <td>17.41</td>
  <td>98.00</td>
 </tr>
  <td>99.84</td>
  <td>58.04</td>
  <td>0.00</td>
  <td>17.15</td>
  <td>98.00</td>
 </tr>
  <td>99.84</td>
  <td>32.16</td>
  <td>1.00</td>
  <td>3.84</td>
  <td>98.00</td>
 </tr>
  <td>59.28</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.28</td>
  <td>98.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>98.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>99.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>99.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>99.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>99.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>99.00</td>
 </tr>
  <td>99.84</td>
  <td>21.57</td>
  <td>0.00</td>
  <td>2.82</td>
  <td>99.00</td>
 </tr>
  <td>99.84</td>
  <td>34.12</td>
  <td>0.00</td>
  <td>6.14</td>
  <td>99.00</td>
 </tr>
  <td>99.84</td>
  <td>35.29</td>
  <td>0.00</td>
  <td>8.70</td>
  <td>99.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>20.00</td>
  <td>99.84</td>
  <td>35.29</td>
  <td>0.00</td>
  <td>10.50</td>
  <td>100.00</td>
 </tr>
  <td>99.84</td>
  <td>34.90</td>
  <td>0.00</td>
  <td>10.24</td>
  <td>100.00</td>
 </tr>
  <td>99.84</td>
  <td>34.90</td>
  <td>0.00</td>
  <td>10.24</td>
  <td>100.00</td>
 </tr>
  <td>99.84</td>
  <td>34.90</td>
  <td>0.00</td>
  <td>9.98</td>
  <td>100.00</td>
 </tr>
  <td>99.84</td>
  <td>34.90</td>
  <td>0.00</td>
  <td>9.73</td>
  <td>100.00</td>
 </tr>
  <td>99.84</td>
  <td>33.73</td>
  <td>0.00</td>
  <td>7.42</td>
  <td>100.00</td>
 </tr>
  <td>104.52</td>
  <td>32.16</td>
  <td>0.00</td>
  <td>6.66</td>
  <td>100.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>30.00</td>
  <td>103.74</td>
  <td>28.24</td>
  <td>1.00</td>
  <td>4.35</td>
  <td>100.00</td>
 </tr>
  <td>129.48</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.54</td>
  <td>100.00</td>
 </tr>
  <td>89.70</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.28</td>
  <td>100.00</td>
 </tr>
  <td>60.84</td>
  <td>20.39</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>100.00</td>
 </tr>
  <td>103.74</td>
  <td>26.27</td>
  <td>0.00</td>
  <td>3.84</td>
  <td>100.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>34.00</td>
  <td>102.96</td>
  <td>26.67</td>
  <td>0.00</td>
  <td>4.10</td>
  <td>100.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>33.00</td>
  <td>106.86</td>
  <td>27.06</td>
  <td>0.00</td>
  <td>4.35</td>
  <td>100.00</td>
 </tr>
  <td>103.74</td>
  <td>27.45</td>
  <td>0.00</td>
  <td>4.35</td>
  <td>101.00</td>
 </tr>
  <td>107.64</td>
  <td>27.45</td>
  <td>0.00</td>
  <td>4.35</td>
  <td>101.00</td>
 </tr>
  <td>109.98</td>
  <td>27.06</td>
  <td>0.00</td>
  <td>4.35</td>
  <td>101.00</td>
 </tr>
  <td>109.20</td>
  <td>27.06</td>
  <td>0.00</td>
  <td>4.35</td>
  <td>101.00</td>
 </tr>
  <td>109.98</td>
  <td>27.06</td>
  <td>0.00</td>
  <td>4.35</td>
  <td>101.00</td>
 </tr>
  <td>111.54</td>
  <td>30.59</td>
  <td>0.00</td>
  <td>5.89</td>
  <td>102.00</td>
 </tr>
  <td>94.38</td>
  <td>30.59</td>
  <td>0.00</td>
  <td>6.14</td>
  <td>102.00</td>
 </tr>
  <td>98.28</td>
  <td>30.20</td>
  <td>0.00</td>
  <td>4.35</td>
  <td>102.00</td>
 </tr>
  <td>103.74</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.54</td>
  <td>102.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>102.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>102.00</td>
 </tr>
  <td>99.84</td>
  <td>17.25</td>
  <td>0.00</td>
  <td>1.79</td>
  <td>102.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>36.00</td>
  <td>99.84</td>
  <td>27.84</td>
  <td>0.00</td>
  <td>4.35</td>
  <td>102.00</td>
 </tr>
  <td>99.84</td>
  <td>29.02</td>
  <td>0.00</td>
  <td>5.12</td>
  <td>102.00</td>
 </tr>
  <td>87.36</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.54</td>
  <td>102.00</td>
 </tr>
  <td>59.28</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>102.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>102.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>102.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>102.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>102.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>102.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>102.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>102.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.54</td>
  <td>102.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.79</td>
  <td>102.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.79</td>
  <td>102.00</td>
 </tr>
  <td>95.94</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.79</td>
  <td>102.00</td>
 </tr>
  <td>85.02</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.79</td>
  <td>102.00</td>
 </tr>
  <td>93.60</td>
  <td>21.96</td>
  <td>0.00</td>
  <td>4.10</td>
  <td>102.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>28.00</td>
  <td>99.06</td>
  <td>21.96</td>
  <td>0.00</td>
  <td>3.84</td>
  <td>102.00</td>
 </tr>
  <td>109.98</td>
  <td>24.71</td>
  <td>0.00</td>
  <td>4.61</td>
  <td>102.00</td>
 </tr>
  <td>120.12</td>
  <td>25.10</td>
  <td>0.00</td>
  <td>4.61</td>
  <td>102.00</td>
 </tr>
  <td>117.78</td>
  <td>25.10</td>
  <td>0.00</td>
  <td>4.61</td>
  <td>103.00</td>
 </tr>
  <td>114.66</td>
  <td>25.10</td>
  <td>0.00</td>
  <td>4.61</td>
  <td>103.00</td>
 </tr>
  <td>122.46</td>
  <td>30.20</td>
  <td>0.00</td>
  <td>5.89</td>
  <td>103.00</td>
 </tr>
  <td>99.06</td>
  <td>29.02</td>
  <td>0.00</td>
  <td>5.89</td>
  <td>103.00</td>
 </tr>
  <td>91.26</td>
  <td>27.84</td>
  <td>0.00</td>
  <td>5.89</td>
  <td>103.00</td>
 </tr>
  <td>111.54</td>
  <td>28.24</td>
  <td>0.00</td>
  <td>5.63</td>
  <td>103.00</td>
 </tr>
  <td>104.52</td>
  <td>28.24</td>
  <td>0.00</td>
  <td>5.38</td>
  <td>103.00</td>
 </tr>
  <td>102.18</td>
  <td>27.84</td>
  <td>0.00</td>
  <td>5.63</td>
  <td>103.00</td>
 </tr>
  <td>102.96</td>
  <td>28.24</td>
  <td>0.00</td>
  <td>5.38</td>
  <td>103.00</td>
 </tr>
  <td>92.82</td>
  <td>28.24</td>
  <td>0.00</td>
  <td>5.38</td>
  <td>103.00</td>
 </tr>
  <td>104.52</td>
  <td>28.24</td>
  <td>0.00</td>
  <td>5.38</td>
  <td>103.00</td>
 </tr>
  <td>108.42</td>
  <td>27.84</td>
  <td>0.00</td>
  <td>5.12</td>
  <td>103.00</td>
 </tr>
  <td>102.96</td>
  <td>27.45</td>
  <td>0.00</td>
  <td>4.86</td>
  <td>103.00</td>
 </tr>
  <td>108.42</td>
  <td>24.71</td>
  <td>0.00</td>
  <td>3.84</td>
  <td>104.00</td>
 </tr>
  <td>109.98</td>
  <td>24.31</td>
  <td>0.00</td>
  <td>3.58</td>
  <td>104.00</td>
 </tr>
  <td>108.42</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.28</td>
  <td>104.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>104.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>104.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>104.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>104.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>104.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>104.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>104.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>104.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>104.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>9.00</td>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>104.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>104.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.79</td>
  <td>104.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.79</td>
  <td>104.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>104.00</td>
 </tr>
  <td>97.50</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.79</td>
  <td>104.00</td>
 </tr>
  <td>87.36</td>
  <td>15.29</td>
  <td>0.00</td>
  <td>3.33</td>
  <td>104.00</td>
 </tr>
  <td>95.16</td>
  <td>24.71</td>
  <td>2.00</td>
  <td>4.35</td>
  <td>104.00</td>
 </tr>
  <td>111.54</td>
  <td>28.24</td>
  <td>1.00</td>
  <td>5.12</td>
  <td>104.00</td>
 </tr>
  <td>113.10</td>
  <td>32.55</td>
  <td>0.00</td>
  <td>6.40</td>
  <td>104.00</td>
 </tr>
  <td>87.36</td>
  <td>33.73</td>
  <td>0.00</td>
  <td>7.17</td>
  <td>104.00</td>
 </tr>
  <td>99.84</td>
  <td>76.86</td>
  <td>0.00</td>
  <td>19.46</td>
  <td>104.00</td>
 </tr>
  <td>99.84</td>
  <td>100.00</td>
  <td>3.00</td>
  <td>18.18</td>
  <td>103.00</td>
 </tr>
  <td>99.84</td>
  <td>100.00</td>
  <td>1.00</td>
  <td>18.69</td>
  <td>100.00</td>
 </tr>
  <td>89.70</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.54</td>
  <td>99.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>40.00</td>
  <td>59.28</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>100.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>101.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>101.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>101.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>101.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>101.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>101.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>101.00</td>
 </tr>
  <td>99.84</td>
  <td>20.00</td>
  <td>0.00</td>
  <td>2.82</td>
  <td>101.00</td>
 </tr>
  <td>99.84</td>
  <td>25.49</td>
  <td>0.00</td>
  <td>4.10</td>
  <td>101.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>31.00</td>
  <td>99.84</td>
  <td>23.53</td>
  <td>0.00</td>
  <td>3.58</td>
  <td>101.00</td>
 </tr>
  <td>117.00</td>
  <td>23.14</td>
  <td>0.00</td>
  <td>3.33</td>
  <td>101.00</td>
 </tr>
  <td>93.60</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.28</td>
  <td>101.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>101.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>101.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>0.00</td>
  <td>101.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.79</td>
  <td>101.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.54</td>
  <td>101.00</td>
 </tr>
  <td>99.84</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.79</td>
  <td>101.00</td>
 </tr>
  <td>102.96</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.79</td>
  <td>101.00</td>
 </tr>
  <td>112.32</td>
  <td>16.86</td>
  <td>2.00</td>
  <td>3.58</td>
  <td>101.00</td>
 </tr>
  <td>109.98</td>
  <td>21.57</td>
  <td>1.00</td>
  <td>4.10</td>
  <td>101.00</td>
 </tr>
  <td>124.02</td>
  <td>24.71</td>
  <td>0.00</td>
  <td>4.35</td>
  <td>101.00</td>
 </tr>
  <td>95.94</td>
  <td>21.96</td>
  <td>0.00</td>
  <td>4.10</td>
  <td>101.00</td>
 </tr>
  <td>106.08</td>
  <td>21.96</td>
  <td>0.00</td>
  <td>4.10</td>
  <td>101.00</td>
 </tr>
  <td>114.66</td>
  <td>21.96</td>
  <td>1.00</td>
  <td>4.10</td>
  <td>101.00</td>
 </tr>
  <td>111.54</td>
  <td>21.96</td>
  <td>0.00</td>
  <td>4.10</td>
  <td>101.00</td>
 </tr>
  <td>110.76</td>
  <td>18.82</td>
  <td>0.00</td>
  <td>3.07</td>
  <td>101.00</td>
 </tr>
  <td>103.74</td>
  <td>12.55</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>101.00</td>
 </tr>
  <td>114.66</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.54</td>
  <td>101.00</td>
 </tr>
  <td>124.80</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.79</td>
  <td>101.00</td>
 </tr>
  <td>135.72</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.79</td>
  <td>101.00</td>
 </tr>
  <td>145.08</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>3.07</td>
  <td>101.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>11.00</td>
  <td>103.74</td>
  <td>14.12</td>
  <td>0.00</td>
  <td>2.56</td>
  <td>101.00</td>
 </tr>
  <td>91.26</td>
  <td>14.51</td>
  <td>0.00</td>
  <td>2.56</td>
  <td>101.00</td>
 </tr>
  <td>80.34</td>
  <td>19.22</td>
  <td>0.00</td>
  <td>3.58</td>
  <td>101.00</td>
 </tr>
  <td>102.18</td>
  <td>19.61</td>
  <td>0.00</td>
  <td>3.84</td>
  <td>101.00</td>
 </tr>
  <td>111.54</td>
  <td>24.31</td>
  <td>0.00</td>
  <td>4.35</td>
  <td>101.00</td>
 </tr>
  <td>114.66</td>
  <td>23.14</td>
  <td>1.00</td>
  <td>4.10</td>
  <td>101.00</td>
 </tr>
  <td>102.18</td>
  <td>19.61</td>
  <td>0.00</td>
  <td>3.33</td>
  <td>101.00</td>
 </tr>
  <td>122.46</td>
  <td>16.86</td>
  <td>0.00</td>
  <td>2.82</td>
  <td>101.00</td>
 </tr>
  <td>110.76</td>
  <td>15.29</td>
  <td>0.00</td>
  <td>2.56</td>
  <td>101.00</td>
 </tr>
  <td>94.38</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.54</td>
  <td>101.00</td>
 </tr>
  <td>97.50</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.54</td>
  <td>101.00</td>
 </tr>
  <td>108.42</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.79</td>
  <td>101.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>13.00</td>
  <td>118.56</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.79</td>
  <td>101.00</td>
 </tr>
  <td>128.70</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.79</td>
  <td>101.00</td>
 </tr>
  <td>138.06</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.79</td>
  <td>101.00</td>
 </tr>
  <td>147.42</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.79</td>
  <td>101.00</td>
 </tr>
  <td>156.78</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.79</td>
  <td>101.00</td>
 </tr>
  <td>164.58</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>101.00</td>
 </tr>
  <td>166.92</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>101.00</td>
 </tr>
  <td>166.92</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>101.00</td>
 </tr>
  <td>166.92</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.30</td>
  <td>101.00</td>
 </tr>
  <td>166.92</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.56</td>
  <td>101.00</td>
 </tr>
  <td>166.92</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.30</td>
  <td>101.00</td>
 </tr>
  <td>166.92</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.30</td>
  <td>101.00</td>
 </tr>
  <td>166.92</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.30</td>
  <td>101.00</td>
 </tr>
  <td>166.92</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.30</td>
  <td>101.00</td>
 </tr>
  <td>166.92</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.30</td>
  <td>101.00</td>
 </tr>
  <td>166.92</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.30</td>
  <td>101.00</td>
 </tr>
  <td>166.92</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.30</td>
  <td>101.00</td>
 </tr>
  <td>166.92</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>101.00</td>
 </tr>
  <td>166.92</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.30</td>
  <td>101.00</td>
 </tr>
  <td>166.92</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.30</td>
  <td>101.00</td>
 </tr>
  <td>166.92</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.30</td>
  <td>100.00</td>
 </tr>
  <td>166.92</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.30</td>
  <td>100.00</td>
 </tr>
  <td>166.92</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.56</td>
  <td>100.00</td>
 </tr>
  <td>166.92</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.56</td>
  <td>100.00</td>
 </tr>
  <td>162.24</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.30</td>
  <td>100.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>5.00</td>
  <td>161.46</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>100.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>6.00</td>
  <td>165.36</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.30</td>
  <td>100.00</td>
 </tr>
  <td>164.58</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.30</td>
  <td>100.00</td>
 </tr>
  <td>156.78</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>100.00</td>
 </tr>
  <td>148.98</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>100.00</td>
 </tr>
  <td>141.18</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>1.79</td>
  <td>100.00</td>
 </tr>
  <td>133.38</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>100.00</td>
 </tr>
  <td>125.58</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>100.00</td>
 </tr>
  <td>118.56</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>100.00</td>
 </tr>
  <td>111.54</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>100.00</td>
 </tr>
  <td>104.52</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>100.00</td>
 </tr>
  <td>97.50</td>
  <td>10.59</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>100.00</td>
 </tr>
  <td>90.48</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>100.00</td>
 </tr>
  <td>84.24</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.30</td>
  <td>100.00</td>
 </tr>
  <td>78.78</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.56</td>
  <td>100.00</td>
 </tr>
  <td>74.10</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.30</td>
  <td>100.00</td>
 </tr>
  <td>71.76</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.56</td>
  <td>100.00</td>
 </tr>
  <td>74.88</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.56</td>
  <td>100.00</td>
 </tr>
  <td>78.78</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.56</td>
  <td>100.00</td>
 </tr>
  <td>78.78</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.56</td>
  <td>100.00</td>
 </tr>
  <td>81.12</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.30</td>
  <td>100.00</td>
 </tr>
  <td height=18 style='height:13.2pt'>4.00</td>
  <td>84.24</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.30</td>
  <td>100.00</td>
 </tr>
  <td>88.92</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.30</td>
  <td>100.00</td>
 </tr>
  <td>92.82</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>100.00</td>
 </tr>
  <td>97.50</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>100.00</td>
 </tr>
  <td>95.94</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>100.00</td>
 </tr>
  <td>89.70</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>100.00</td>
 </tr>
  <td>82.68</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>100.00</td>
 </tr>
  <td>75.66</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>100.00</td>
 </tr>
  <td>78.00</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>100.00</td>
 </tr>
  <td>74.88</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>100.00</td>
 </tr>
  <td>77.22</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>100.00</td>
 </tr>
  <td>78.78</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>100.00</td>
 </tr>
  <td>74.88</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>100.00</td>
 </tr>
  <td>79.56</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>100.00</td>
 </tr>
  <td>81.12</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>100.00</td>
 </tr>
  <td>79.56</td>
  <td>10.98</td>
  <td>0.00</td>
  <td>2.05</td>
  <td>100.00</td>
 </tr>
 <![if supportMisalignedColumns]>
 <tr height=0 style='display:none'>
  <td width=64 style='width:48pt'></td>
 </tr>
 <![endif]>
</table>
</body>
</html>
I'll try and take a look at the log after lunch. :)
Well, it looks like I'm an idiot and forgot to keep rpm in the log. :coy:
Anyway, I checked the .csv file you sent me and it doesn't look like the log was at WOT? Also, by looking at the data, there seems to be something weird going on here. For some reason the TPS only hits 100% during 2 data points in the log. Also, it seems as though the Front O2 sensor is giving you some weird values. I'm guessing that you are using MMcd as your logging software?
If so, then O2-F means nothing and O2-F is actually going to be O2-R. I'm going to have to guess that this log was taken during a normal cruise around town? If that's the case, then I pretty much chose all the wrong data.
According to your profile, you don't have anything to tune with, so there really isn't anything you can do with the tune. If that is the case, all you can do is check and make sure all the parameters at WOT are where they should be. The most important being knock. Make a pull from 2.5k to redline and email me that log. Looking at your FT's in the other log, everything looks OK and the O2 sensor seems to be cycling like it should.
Sorry for the confusion, but I was really busy at work yesterday and didn't have time to go over the log. I just assumed that it was at WOT and wanted to get it posted in the thread for you. I promise, I'll do a better job next time. :)
Yes, I am using MMcd. I have the Datalogger on my palm 3 but i have no idea how to get it to show up on my computer. I have heard alot of people say to do a 3rd gear pull. I have my own shift box so I can get a log of that later today. I can try to get a Log on the datalogger software too. I know it saves it, but i have no clue on how to go back and read it.
Not sure what you mean here....MMcd is the datalogger software and the Palm + software is the datalogger. Or do you mean that you are trying to log with the PC?
When i make those logs, I click on MMcd on my palm, then click New. I can log from there. There is also a Datalogger application on the palm 3 that I can save a log with. that is what I don't know how to use. I can see the logs, but i cannot replay them or view them on my computer.
My menu on my palm is :
Datalogger
DSM logger
Multiwatch
Documents
MMcd
Palm'n'Stein
