2g Evo316g Records....
The 11.81 run is posted somewhere on the link forums or I can email it to you if you need me to, just pm me your email address.
I just stuck 11.81 in the search bar and found it. That is one lean ass log, 13:1 tapering down to 12.5:1. From the looks of it, that wasn't all it had. If you were able to utilise NLTS, squeeze a little more timing, and stableize those AFR I really think you would have a 11.4-11.6 pass. None the less I'm impressed, And it gives me a little hope for next season to see 11's.. I cant seem to get over 15deg advance on 21psi with pump gas/M7 meth kit..
Are you going to be running that setup in 07, or are you moving on?
New setup for 07 if it even sees the road.
I know the car had more in it, obviously with Josh driving the car just a few times he proved that.
I think the o2 was reading wrong becuase the car ran great when the plx showed that lean. I also had a problem with the fuel pump that a rewire fixed and added a new o2 sensor and with the same tune the AF's droped a few .10ths at WOT. The car was running no leaner then 12.6:1 after the shootout.
The car had more ET in it but I honesltly believe that the power was pretty much maxed minus adding a smim but I am not sure that would have gained anything at all.
