2G engine in 1G eclipse with 1G head
eclipse_krc
Jun 20, 2006
Vilnius, Europe
i have 1g eclipse GS and i'm thinking is it possible to put 2G 2.0l engine with 1g ported engines head in 1g eclipse. i have heard that 2g model engines with 1g engines head makes higher compression in cylinders? is it right?
By 2g engine are you refering to the 7bolt 4g63t?
The n/t 420 def does not bolt up into a 1g...
If you are going turbo with the 4g63 then lower compression is what you should aim for to run more boost. I am unsure if that combo makes higher compression, but you need to explain more details first on the specific engine you are planning on swapping.
There is no such thing as a 1G or 2G engines. All turbo engines are 4G63 and depending on years, they are either 6 bolt or 7 bolt.
Which year is your 2G engine? and Which year is your 1G engine?
If you have a 1.8L SOHC engine on your NT, that is a 4G37 engine and has nothing in common with the 2.0L DOHC 4G63 engines.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
