2g ECU removal
Chris95GST
224
Aug 12, 2003
Is there any trick to removing the ECU from a 2g. I haven't tried moving it, but it looks like it's bolted down and the bolts look like a huge PITA to take off. This is for a 1995 GST. Thanks for any tips/help.
1. Disconnect battery.
2. Remove both side panels in the foot wells so you can access the ECU (located below and behind the radio).
3. Remove the 4 plugs from the ECU via the drivers side foot well.
4. Remove the 2 bolts from the ECU via the drivers side foot well and the 1 bolt via the passengers side foot well.
5. Remove ECU.
