ECMlink 2g DSMLink tuning issues!!!
RRE has really nice gaskets for almost $ nothing. You could pick up some cork gasket, I've used it on a couple small street turbo's, and as long as your not raceing it 100% all the time, it should work nice an dandy.. SS gaskets need suuuuper smooth surfaces, your better off just not using one.
I'm looking into that copper one now.. That looks like it would crush well. Cork would just burn up, I wouldn't use that.
Ok... manifold came yesterday.. Finished everything today. Love the new manifold by the way. Seafoam'd right after install, NO SMOKE until the muffler. Before the new manifold there was smoke pouring out of the turbo to manifold gasket, the front o2 sensor, and the crack in the manifold.
Did pulls, pretty much the same thing... 3rd gear pulls will yield mid to high 10's afrs, but if I just punch it in 5th and I'm not high up in the RPMs in 5th AFR's will show up lean. If I step on it in 5th gear but keep the wastegate closed by not going WOT AFR's stay in low 10's. I'm thinking about buying a new WB o2 Sensor, but I don't know if this is a good idea... Does this kind of issue sound like an o2 sensor issue?
Well, no one answered so I bought a new sensor. It comes tomorrow. $70 shipped from ExtremePSI isn't that bad. Worst comes to worst, I'll just sell it. I'll post up tomorrow my results...
Ok.. replaced the wideband o2 sensor.. nothing changed... I just want to mention that I have both a manifold mounted external wastegate and my wideband is placed in the stock rear o2 sensor location. Could it be that the sensor is too far?
Because even 3rd gear as you say should still be pinned at 10.0 with fuel settings on 0, but it shows mid 10's on the pull.
i was wondering if you ever calibrated the WB-02 sensor to open air. or AEM does not require this like a LC-1 02 sensor.
I've been tuning my car for a while now (used a dyno's wideband), but I JUST fixed my wideband two days ago. It wound up being the placement of the sensor. I had a bung welded right after the bend in my downpipe before the flex pipe and now it works fine. Everyone told me that it would make no difference (had it in the rear o2 location) because a sample is a sample, but when the wastegate opened up it always went crazy. Wideband works flawlessly now.
  • For sale 2g 2G 7 Bolt Lower Timing Cover
    2G 7 Bolt Lower Timing Cover $80 + shipping & paypal fees* there are a few flaws ( pictured )...
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
