2G 2g DSM 6 bolt stroker
Tommygun1
May 8, 2024
Ancienne lorette, QC, Canada
Hello guys, I just finish my build motor, it a a 6 bolt engine with : bottom block: piston Wiseco stroker, rod Eagle , crank 100mm OEM and main girdle Kiggly.
All ARP bolt all engine. So a 2.3 liters. I install also some GSC r2 camshaft, those are 274 /274. 12.1 mm lift 6 degree more duration of the s2 GSC. I got the spring reteiner titanium, its the setup for my cam. I continue Cometic head gasket, HLA Kiggly in the head for keep 15psi to the rocker roller lifter. I install tubular T3 manifold with a GT3582R turbo with .082 . It's a street car? Don't forget. Down pipe and full 3 inch exhaust system. Full intake pipe 2.5 inch with fmci intercooler. 525 Walbro fuel.pump, 2150 cc injector feed 8an return 6 an, Jays Racing alternator relocàlisation in the back, DSMLink v3, automatic transmission shift kit , Kiggly clutch , IPT end cluch, Forced Four dsm2.
Congratulations on your build. Please put this information in your profile so that if you have questions or issues later on we can reference it. It will be easier on everyone if you organize your list.
