Ludachris
Founder & Zookeeper
- 8,880
- 4,727
- Nov 12, 2001
Newcastle,
California
So I've been planning to modify the dash in the Eclipse for a long time. I just want something that sits a little lower and doesn't look so... 1991. Here's what I've done so far.
I took some depth measurements to see how much needed to be trimmed from the back side (where the dash meets to windshield) and took off about 5 inches. I traced an outline of the 1g dash on cardboard and used that for my cutting line to get the contour right. I then had to take some material off the sides to get it to fit all the way in, but not very much. The 2g dash is much deeper than the 1g dash, and only slightly wider.
I still need to do a little bit of trimming on the driver side for a better fit, but overall, it looks pretty close. Then I'll tackle the door panels. I'm keeping the 1g door panels. The doors don't close right now - I need to take out a little bit of material on the door panels to get them to close and then will attempt to add some material to get the shape of the door panels to match the dash. I'll then wrap the entire door panel in vinyl - will probably wrap the entire dash to match. I will also need to create some mounting brackets to meet up with the stock 1g mounting points - figure some aluminum and some rivets/epoxy, with some rubber material to eliminate rattles will do the trick.
Once that's all done, I'll attempt to get a 2g center console to fit... and I have some ideas for the gauge cluster but that will warrant a new thread. Actually, I need to just create a build thread I guess. Just wanted to share this with other fab guys.
This is something I haven't seen anyone else attempt. Hope it inspires others to try it, or try other solutions.
