Resolved 2g brake and clutch pedal grommet hack
osu234
5
Sep 20, 2022
Columbus, Ohio
I have a 1995 Eclipse GSX with 5k miles that sat in a garage for 25 years. I started having brake lights staying on and eventually the cruise control not engaging. I found the blue grommets on the pedals had dry rotted and crumbled leaving just the mounting hole. After reviewing several posts here I remembered using some suction cups earlier in the day on a cabinet slider that came from Amazon. I knew that I had extras leftover so I grabbed them. To my surprise the stems mounted perfectly in the clutch and brake pedal grommet holes with enough tension to hold them in. The suction cups work as a guide and backing plated to align the nub on each switch. Working great so far.
Just my fix for grommets that seem to no longer be available. The suction cup is between 1/2”-3/4” across and has a 1/4” ribbed shank.
Here is the part number for original stoppers (MB151298) if you wished to have them instead.
-Daniel
Hello Daniel
Wow. Thank you. I will order four. Two to replace the ones installed and backup set for some day. I searched the post’s several years ago and didn’t see these. Much appreciated.
Denny
  • Wanted 1g 6 bolt rear timing cover tins both sides.
    6 boltRear timing cover tins.
    • Robert503
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted 2g WTB: 2G Eclipse GSX / Talon TSi AWD (1995-1999)
    Looking to buy a 1995-99 AWD Eclipse GSX or Talon TSi — running or project, rust-free bones...
    • Total Eclips3
  • For sale Wideband
    • Briant91
  • Wanted 560 injectors
    • AllanL
