Resolved 2G Battery->fuse box->alternator
3kgtaddict
5+ Year Contributor
42
10
Apr 27, 2020
Albuquerque, New Mexico
I just pulled a mess out of here and now I’m hoping someone can help make sure I’ve got it right so I don’t catch it on fire again like the last guy did!
I know there’s supposed to be a 100a alternator fuse in there and Some others I’ve seen also have a 60a fuse on that second slot, but my lid says I only need a 100a (assuming I have the right lid)
4 white wires going to rear of fuse box,2 to rear of 100a alternator fuse slot, 2 to the spot next to it
2 white wires coming from the alternator going to the front of the 100a fuse slot
Also there’s that little white/red stripe wire coming from the battery going to another fuse on the other end, is that Right??
Then I’m assuming I’ll need a fuse with male terminals to go down into there? There aren’t any males coming up like there are for the other fuses??
I only found these two pictures online and I think they’re from a newer one . Mine is a 95 with a 94 motor
I went through jafromobiles videos and found what I needed so never mind this I’m sorry!. I can’t figure out how to delete this post so I’ll just say for anyone who may have this issue, the 4 white ones from the battery need to be swapped to the front of the fuse block, and the 2 from the alternator go to the rear of the fuse block. Then the 100a fuse to connect 2 battery and 2 alternator. That’s all I had wrong in my pics 🤦‍♂️
Check it out on jafros video at 2:55
