2G 3000gt VR-4 Big Brake Upgrade Kit Only $365
I'll just fab somethin up
No, 2G started in 1994. what makes you think that you have 2g calipers? look at the picture in my first post in this thread, are they the same size????
I own an evo and a talon, i'm pretty sure the firewall mounting is different. Do you want me to compare the m/c brackets???
well i guess if he makes something that hold the m/c in place it shouldnt be a big deal. i just remember seeing it and i told him. i guess we loose a lot of feel b/c the m/c move when you press the pedal. if you have someone push the pedal and you look at the m/c you can see it move. :thumbdown
I have those exact same calipers, so I got 2g. Right? Doesnt matter, I dont care, they are better than what I had none the less.
No need to compare brackets, It would only take me an hour at work to make a temporary bracket to see if it helps with the littl mushyness, thanx though
BTW, those brackets in the pic are identical (almost) to the ones I designed for my setup......hrrmmmm..... whos been in my head? LOL
All in all, id say this mod is awesome, some one aleady beat me to the product though,.... AGAIN! (damit)
the3kgt2 said:
what offset are your 17" rims without the 25mm spacers?
you can also grind down the sides of the calipers for smaller wheel spacers/larger offset
I have 17" konig holes with a 45 (Ithink) mm offest. I wanted to keep the Mitsu letters on them because I think that makes the mod! I dunno, call me anal but it just wouldnt be the same without it.
Besides, I like the new aggressive look I got with the 25mm spacers
My spark plug cover does NOT have a mitsu logo or lettering on it, what kinda messed up talon are you driving?
ANYWAY, we're a little off topic here.
do you know your braking distance now that you went to 2g vr4 calipers?
Robby Camero said:
Incase you didnt realize, our motors are mitsu and so is the driveline. LOL, I think the mitsu logo rocks and is the main reason I used these calipers. To each their own I guess. LOL
exactly. i could have saved for a big brake kit but then i wouldn't have the mitsu on the side i put photos up a few posts back too
:thumb: Looks hot.
Thanks for clearing up the skepticism, by the way. I have warped rotors and I gotta do wheel bearings.
So the brackets they had on the site are almost identical to yours? ... And if I did want to grind off the "Mitsubishi" logo (paint them red and buy the brake decals some guy is selling I saw on another thread) will that eliminate the need for wheel spacers? 25mm spacers seem like alot, and I don't feel like rolling my fenders.
I just got a set of wilwood calipers from http://www.pitstopusa.com for $200. they should fit like the 2g's with a simple backet and a a 2g rotor. btw, the link to the caliper pdf is broken, could someone else send it to me or post the picture. I need the dimensions of the bracket
