272 cams what idle rpm??
jdunbar10
133
Jan 30, 2007
edmonton, AB, Canada
so i have the new motor running today its got 272 cams no adjustable cam gears running at about 15 degres for timing whats a good rpm that i should idle at??
i have a few small boost leaks and such to fix up tomorrow but just curious
750rpms if it idles good. If you have to slowly go up to 1000rpms till you get a good idle that you feel good about. If its BC 272s it will idle no problem. Its the more aggressive 272's, like kelfords, that can give you issues at idle.
