andymoraitis
- 3,241
- 161
- Jan 25, 2004
Utica,
Michigan
RedTurboEclipse said:Geez I can't even run 25 psi on pump gas with my 50 trim.
25psi on 93 octane
14:1 A/F at the onset of boost tapering to 11.5:1 at 4000 and above
12 degrees timing advance (don't try this on cast internals) with more timing in the midrange from 2-4K
42 psi fuel pressure
2 counts of knock
Dejon Sidemount and an EPROM ECU
I can run 28 psi on 100 octane or more than 30 on 110 (too bad the boost gauge doesn't go above that). Once the boost comes on, the car's a freaking blast.
