20g install questions!
prophecy7115
345
4
Apr 23, 2005
Miami, Florida
OK i just purchased a super 20g from Hans, and i would like to know were i can get a oil feed line? if not what measurements. I need so i can just buy the line and fitting if nothing else works. What do i do with the bolts for the turbo manifold threw the -bolt on flange plate and to the- turbo? will the bolts from the t-25 fit?
~I have questions for the oil feed line measurement so i can go get one!
~The bolts that go from the turbo from the manifold.(will the t-25 be long enough?)
~And will any modification be made like a radiator fan or bending i don't know about?
Thank you
just helped install one in my friends car about 2 months ago, it wasnt a hahn, it was a 20g he had bought from slowboyracing, anyhow, heres what i know from it, I am not sure if they are the same or not..
-oil feed line is the same as 14b 16g, you can buy them all sorts of places, my friend already had a 14b so we didnt have to get one, try www.slowboyracing.com
-you can reuse the bolts, however, one is a stud with a nut, which can be a pain, its recommended by most to order 1 extra turbo to manifold bolt.
-if it is internally gated the wastegate actuator will most definitely be in the way of your radiator fan closer to your passenger side, you will need a slimline if its internally gated. Im not sure about the other fan as he was only using the passenger side one, which he had to have replaced with a slimline.
call Hans and ask him. does he have a US phone number or do you have to call Sweden?
first place you might want to try is where you bought the turbo from, Hahn Racecraft. If you look on their site it tells you what you need.
thanks alot guys!!!!! i have evrything good but the slim fance hopfully i can fit it in there.
Also anybody have a size for the 14b, 16g,oil feed piece is?
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
