GSLENK
- 1,416
- 55
- May 25, 2011
DC,
Maryland
I grabbed a 20g and I'm a total noob to upgrading turbos. From what I have searched so far, this is all I know: (my 20g is the tdo5 exhaust housing, with the big 16g style compressor housing)
-20g is bolt-on (well except for the following...)
-I should feed Oil from the OFH
-I should use a restrictor around .08" hole to maintain proper pressure
-I need to clock it to point down (the compressor outlet) (it doesn't point down...)
-I have all the intercooler piping and stuff needed to install it.
-I need all new gaskets to replace any ones i am separating.
What I an pretty unsure about:
-Use stock oil drain?
-What size fittings for all oil drain/feed, what size line, Diameter (i know better than to ask for length)? SS flex tubing right?
-Coolant lines bolt right up? If not... What sizes again for fittings, and lines?
This should be pretty easy for those you who have done successfully... And my searches haven't yielded me specific enough answers to be confident I'm not about to screw something up.
Is there anything else Im missing? I want to get this turbo on and running in a day. Preferably in a few hours.
) major, and my physics teacher was an a-hole. My brain snapped, and im a permanant overthinker. sometimes it pays off...
doh
