BOBS90TURBO
- 581
- 5
- Sep 18, 2002
Tulsa,
Oklahoma
I need to know if a turbo seals can go bad and have no shaft play at all, feels like new.
It has some oil inside the compressor inlet and on the wheel, Just a tad of oil inside the intercooler pipe, none up by the intake elbow.
Only blows a puff of whte smoke if sitting at idle for a minue or so right when you hit the gas it blows oe quick puff... Headgasket and compression are perfect at 170 psi
Boosts hard and only normal black/little white under heavy boost 20psi..
Is it possible to hae bad seals and no shaft play AT ALL!!!!!!!.
The pic shows no oil, I wasjust showing where the oil is showing up at.
