2010 Video Recap
9!'clipseDOHC
Moderator
4,913
484
Aug 24, 2003
El Paso, Texas
I put together a little video last night of my DSM over the past year. I know it's only October but my wedding is coming up in January so blowing money on my car is being put on hold until 2011. 2010 has been a great year for my DSM: I finally built my 4G63t and did the turbo swap, I raced at the first annual Texas Mitsubishi Shootout at San Antonio Raceway, and I made it out to the local track, El Paso MotorPlex.
[video=9!'clipseDOHC 2010]122[/video]
My 1g DSM in 2010:
Non-turbo to Turbo swap
2010 El Paso DSM Spring Cookout and Cruise
1st Annual Texas Mitsubishi Shootout at San Antonio Raceway
Racing at El Paso Motorplex
Stock turbo, stock fuel injectors, stock intercooler, stock ECU, full interior, street tires, FWD, 14 pounds of boost.
Coming soon: Punishment Racing FMIC, DSMlink V3lite, Fuel Injector Clinic 850 cc fuel injectors, Buschur Racing TD05/6 hybrid 20g, Tial external wastegate.
TX Mitsubishi Shootout pictures taken by Nikki Deleon from texas-dsm.com.
Video recording thanks to my wonderful fiancee Becky!
Song is You're Going Down by Sick Puppies.
Also since my last update I have replaced the front control arm and rear track arm bushings with Energy Suspension poly bushings, replaced the lower ball joints, low mounted my battery, removed my cruise control, installed my Buschur Racing polished heatshield, replaced the throttle body shaft seals, and gotten rid of a few more boost leaks.
The car is running great! It idles perfectly, boosts quickly, and gets crazy good gas mileage (high 30's-close to 40 mpg).
Here are some pictures really quick:
attachment.php
Old ball joints and bushings.
attachment.php
New control arm bushings.
attachment.php
Low mounted battery, Buschur Racing polished heatshield, and non-cruise throttle cable.
That's all for now. Look for more in early 2011! :thumb:
Nice work on the build.:thumb: I know it took alot of work and I'm proud of you for doing the swap.:applause: The engine bay looks great and very nice attention to detail too. The 20g with bigger injectors etc. will make that thing come alive.:hellyeah: Just wanted to tell you what a nice job you did and good luck with the changes.:)
Thanks a lot Gravedigger! That is very kind of you! I am very proud of myself as well. The entire swap went without a hitch. Apparently I've learned from all the mistakes I've made over the past 7 years with this car that I was able to do it right this time! Thanks again!
Did you keep the old motor for parts?
