2.0 swap
95weclipse
307
3
Jun 26, 2009
LaSalle, Illinois
Alright guys I know this may be beating a dead horse. I cant find any info on this. I want to swap my 90 1g 1.8 to a 2.0 non turbo (for now) I am getting a supposed blown motor, Ill find out when I tear it apart. Im getting the motor, trans, ecu, wiring harness, shifter base and cables for cheap. I was planning on rebuilding the motor, I have a good crank and rods, I was gonna put turbo pistons on the rods I have. My question is where can I get info, or does any one here have info on putting a 93 harness in a 90, I was told it can be done, I dont need a training coarse in DSMs, I am building 97 gsx as my toy, only swapping the 1g because the 1.8 burns oil really bad, so please no trolls, or haters, so only comment if you know where to get the info or have the info your self
This article covers the differences in the engine harness between a 1990 and 1991+ model; read it and attend to the items that differ: The 1990 Engine Control Wiring Harness
As for the swap itself, this covers pretty much everything else. Note the small bit near the bottom of this post pertaining to 1.8L models. By using the 1993 harness, you eliminate having to do any of the "extra" wiring that is listed for the knock sensor, 7th wire on the MAF, etc.: Installing a turbo 4g63 into an nt 4g63
