1st time6nolt build..Need advice on parts list.
LouD
Jan 10, 2003
LONG ISLAND, New York
I drive a 90 Gsx. Right now its running 12s but Im lokoin to get into the 10s. I am lookin to get 450-600whp. Im not too sure about what kind of tranny, trasfer case , driveshaft i might need for that kind of power. Im not sure which cams i want to go with. I want the holeshot but i need more top end. thanks
I would at least go with a shep stage 3 so you will be able to shift it and accually have fun driving it. As far as the transfer case and drive shaft as long as they are in good condition run them till they break or start making noise like we all do. There are many 10 sec talons out there with stock driveshafts and t-cases. Look at the u joints for play in the driveshafts and you may need new carrier bearings if yours are making noise (thump thump thump) on launch If not at that point yet I would pump silicone in the top hole of the carier bearing assemble to stiffen it up.
Do a search on your other questions you have on your motor build this has been asked many times.
there is no specific setup that will get you to your goals. Many are particular to this rod and this piston setup. Doing this or doing that.
Im in the process of parting togeather an engine in the lower end of what your looking for. Using eagle rods probably ross pistons. A good cam for what your looking for would be a fp3 or 3x. Dual valve springs, Titanium retainers and all the goodies that go with a build head. Only need minor porting in the head as well.
What its going to come down to, as im sure you know it tunning.
Good luck with your build.
