pagosa dsm
- 509
- 131
- May 7, 2005
pagosa springs,
Colorado
I did something a little different with the rear sway bar links. I have heim joints at both ends with a male an a female theads. It worked out very well. I attached a heim joint to the sway bar. Then at the lower control arm. The sway bar end was bolted to it. The lower control arm,I bolted 2 1 1/4" angle on the bottom of the control arm. I bolted the heim joint beteen angle iron. Measured spacers beteen the heim joint for a nice fit. I had to inlarge the hole in the control arm a little.
