4gfun
Supporting VIP
- 2,012
- 56
- Dec 10, 2007
Ask Me,
Virginia
I got burnt on my Laser which has a bad engine and manual trans. I wanted to work on the trans before I worked on the engine so I pulled the trans and set it aside. For reasons beyond the scope of this post, I don't want to put the trans back in yet.
I'd like to pull the head while the trans is out, but from my below writeup I have to pull the driver's side engine mount.
The passenger mount is out already and so is the front mount. I am guessing that the engine will end up on the ground if I pull the passenger mount while pulling the head assuming it's the last mount?
If so, any workaround?
Thanks.
http://www.dsmtuners.com/threads/writeup-on-removing-1g-cylinder-head.477456/
Thanks.
