Resolved 1G What is this hole on the intake side of the head
RLSchwabe
126
30
Mar 21, 2014
Colorado Springs, Colorado
Can anyone tell me what the hole circled in red is for? Someone filled it with silicone. It's a 91' 6-bolt. I've searched the forums but couldn't come up with an answer. Thank you.
EGR port. If you want to block off there, remove that silicone and tap for a 1/8" or 1/4" plug to block off. If you let that port open and block off the EGR valve on the stock intake manifold, use a OEM or aftermarket metal intake manifold gasket. Shouldn't use a paper or thermal intake manifold gasket if you let the port on head side open.
Search with Head EGR Port Block Off. You will find many info.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
