1G unkown valve on the side of intake manifold
Fehrion_sit
274
Oct 6, 2009
chalfont, Pennsylvania
im doing a head rebuild and this valve is attached to the bottom side of my intake manifold, it was not hooked up to anything and i removed nothing from it, does anyone know what it is ?
hahah, i havent touched it really, i didnt even think to see if that is blocked off, i took pictures before i left the shop. if its not blocked off, and i block it off, ill fail inspections correct ?
They probably just look to see if it's there, not if it works. You might have trouble if they do an exhaust gas analysis with the car running, on rollers, but I think they only do that in Cali and in big cities. If you really wanna be safe, just hook-up a bunch of vacuum hoses to all of your vacant nipples. Umm, nipples.
i think im just gonna make a legit plate to block the inside and then bolt it back up, its not doing anything so why not, is ther an internal passege in the manifold, or it just pulls exhaust through a vaccum line ?
