karbon
- 906
- 5
- Feb 23, 2004
Akron,
Ohio
Months after the swap I decided I wanted EGR again. I tried to follow RRE's suggestion to get the 2g EGR working on the 1g throttle body and it's still not working. I think it's a vacuum routing problem. Maybe I'm just not seeing this correctly, but RRE says that the 1g TB doesn't have vacuum at idle and the 2g does on the EGR line. The 2g EGR wants vacuum, so plumb it from the P line. Fine. Then hook everything else up as normal. Did that and it's still not working. Here's a schematic of how I hooked it up from directions from RRE and Taboo's site:
TB 'P' line --> EGR solenoid leftmost nipple
TB 'A1' line --> T fitting
T fitting one end --> EGR body nipple
T fitting other end --> rightmost nipple on EGR solenoid
EGR end/top nipple --> middle nipple on EGR solenoid
This is how I interpreted the schematic. Someone set me straight. After probably 1000 miles like this, no change in gas mileage nor does the EGR report a readiness state. It's definately not working correctly when it did before the swap.
