1g Throttle body elbow vs 2g
yoshimitsuspeed
674
5
Jul 17, 2004
portland, Oregon
So the 1g TB is 60 mm and the 2g is 52, as are the TB elbows.
Are the uicp hoses the same diameter? The 1g looks smaller in pics but I am thinking it is because it flares up to 60 mm.
The bolt pattern is the same though between 1g and 2g right?
Bolt pattern is the same . The hose is not , it does flare at the end . The continuous opening on the 2g is larger .
So on a 1g setup it would be better to port a 2g elbow out to 60 mm instead of using a 1g elbow? Is this correct?
But does that mean the 1g uicp is smaller too?
If so you would have to adapt it to a larger diameter.
If they are different what is the diameter of the 1g uicp?
I saw a faq talking about porting a 2g elbow out to 60 mm but you could only do it in the flange. The outside diameter of the 2g elbow is less than 60 mm.
ok, if you get the 2g elbow, which has a bigger opening at the uicp, but also is bigger throughout, you will need a bigger uicp, something like 2.25" is fine for a basic setup..
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
