1g/2g Throttle Body Elbow Mod!!!!
DSMpwr25
110
Oct 29, 2004
Gloucester, Virginia
I am going to run a 1g head/7 bolt block, with a 1g intake manifold, with a bored out 63mm throttle body so i decidied to do some custom work so, i took the 1g flange(60mm) that leads down into smaller piping. now i also have a 2g throttle elbow, flange(52mm) but the piping stays the same all the way threw so........i cut the 1g elbow, then cut the 2g flange off, put them together, measured them up to fit each other. Now all i got to do it weld some, grid down some metal, a little paint, i will post pics as soon as i can. :thumb:
i just ported my 2G elbow to match the 1 G gasket. sounds like you did basically the same thing but by combining 2 elbows?
yea, it looks sweet, i just have to weld it tommorrow, then clean out the inside, and paint. i also smoothed out my 1g intake manifold, it looks like a 2g intake manifold now, trying to be a sleeper, but also i like the clean look
