1g talon
not so stockTsi
Oct 25, 2010
waterville, Maine
Hey guys i'm new to the DSM world and I have recently purchased a 1990 eagle talon tsi. As of now the car is not running, things that i know i need.. a Mass Air Flow sensor or learn what the gm bypass thing is thats in the car does and how to wire it back together, and a starter. The car wines when you try to turn it over sounds like the starter isn't releasing like its froze. i think thats the problem however i know nothing about these cars. I just hope i don't have to put 3k into it to drive it. that will come down the road once i know more about these. thanks for any help and input you have thanks:banghead:
try getting a starter, then go from there? keep us updated.
new starter is in and still nothing.. cranks and cranks for about 3 seconds and then backfires but will not start..? this will happen as long as u want to turn the key
attachment.php
A picture is worth a thousnad words. :thumb:
You need to check all the basics like compression check, check your fuel pressure and check and make sure your timing is spot on. Also does the car have a mass air flow sensor because in the posts above you said something about it not having one.
Sent from my HERO200 using Tapatalk
Check timing, it may be off by a couple of teeth. if so you caught it before bad things happened.
When you were talking about the getting a new MAFS you do have one on the car right? And was that a GM translator for 3 GM MAFS?
im picking a new maf up this weekend and there isnt one on it right now. the gm bypass i have no idea anything about
