greddy_1700
- 1,036
- 91
- Aug 27, 2006
Regina,
SK, Canada
Hey, Just wanted to double check with you guys since I am away from my car for the next three months. On the 1g, are all the rear calipers the same? Like will any rear caliper from 90-94 be the same?
Also since I havnt looked at my car in a while, is there a rear bracket? Or does the caliper just bolt straight on to the hub?
I am getting stuff powdercoated while I'm away from home so I want to make sure I get everything I need coated.
Thanks in advance,
Garret.
Thanks in advance,
Garret.
I think the question was if a 91-94 rear caliper would fit on a 90 without any modification. Autozone is bad, really bad, but occasionally they do manage to put the right year part in the box (I've had rebuilt 96 mirage CV axle end up in a NEW 92 Eclipse CV box before) so I'm not surprised that they can replace with like kind parts. I'm trying to find out if 91-94 GSX rear calipers, which are larger w/o going aftermarket, are similar enough in brake line placement (which seems likely) to work.
