1g Prothanes
killab443
602
3
Nov 24, 2003
Howell, New Jersey
I installed Prothanes in my 1g fwd. It comes with the crummy inserts for the front motor mount like everyone knows. Is it possible to buy just the rear Prothane mount so I can use it in the front? If so were can I order it.
It is possible to fit the mount that is suppose to go in the rear into the front.( cut out the old mount and do it just like you would for all the other full mount inserts) How do I know? I did it by mistake instead of putting the insert in the front. I just had to bend the brackets over a little bit the get the front motor mount back in place. So if you can by another rear mount individually somewhere, you could make it work.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 4G63 4 Port Mac Boost Solenoid with RaceArt Mount
    4 Port Mac Boost Solenoid with RaceArt Mount $60 + shipping & paypal fees* these RaceArt mount...
