1g or 2g knock sensor
tmannix
Aug 25, 2006
glendale, Arizona
Hi. I've done some searching on here, but I can't find a definate answer. If I have a 2g eclipse w/ a 1g engine, do I need a 1g or 2g knock sensor? Thanks.
You match your knock sensor with your ecu not engine.
So if you still have a 2g ecu you need a 2g knock sensor.
Thanks, but when people swap out engines, does the original ecu stay in the car, or does a new ecu come with the new engine? Thanks
